Changing line weights in Elevation
Where is the ability to change your elevation line weights? Such as a brick pattern or something of that nature.
I'm not talking about fills.. just need to change the line weights of the way my walls look in elevation.
So basically the brick "fill" representing my brick walls prints out too dark.. do I have to use the fill tool or can I change the line weights of my walls in elevation?
The fill pattern color is set in the Material settings, in this case. You can select either "Element Pen" (same as uncut outline) or a pen of your choosing.
Okay thank you.
Whats the easiest way to change a wall pattern you have selected?
Or do you have to select the pattern you want to change in the materials window and it will change all of that pattern to the same pen?
