Changing the version of a template file
I have made a template file in the past for AC21.
I have recently swapped to AC22. Is there an easy way of changing my library from AC21 to AC22 without having both libraries linked while still using my current template file?
Basically I just want to keep using my template but have the library as only AC22.
Thanks
Have a look in the reference manual.
There is a section there on migrating libraries - also other things you may need to look out for.
It will save me from typing out the instructions.
Thanks Barry,
Ill have a look through it
