2007-03-06 08:09 PM
2007-03-08 10:41 PM
Jere wrote:the 'project' origin of the complex profile window is the point which follows the reference line of your wall/beam in the x, y, z co-ordinates that you specify. think of the rest of the profile as an extrusion along that path.
Ok, i got a little confused there. So when I'm drawing complex profiles, let's assume a wall for now, what direction and relationship should the profile have in reference to the reference point?
2007-03-08 11:18 PM
2007-03-09 12:26 AM
Link wrote:
Ben's right, there was a misaligned fill - which is a complex profile killer. The fill near the top right corner is out by .02 degrees. Drag that node on top of the other node and everything will be fine.
Link.
~/archiben wrote:
you had duplicate stretch lines in there - probably not a problem - but what i forgot to check for was duplicate fills: if there are duplicate fills, archicad may be trying to extrude two identical geometries along the same path - that would also account for the crazy kind of co-planar highlighting effect i saw in the 3D window . . .
they're delicate i suppose. 'handle with care'
~/archiben
2007-03-09 06:24 AM
2007-03-09 04:30 PM
2007-03-09 10:36 PM
