2009-02-27 09:55 PM
2009-02-28 01:30 AM
2009-02-28 03:03 PM
2009-02-28 07:33 PM
2009-02-28 07:52 PM
2009-03-02 08:09 PM
Cons and things to watch out for.This is the problem I am having except in ArchiCAD 12. One of the profiles I am using won't show the cut lines. I had been opening and closing sections and the profile looked fine but then all of a sudden, I opened up a wall section and all the cut lines were gone, Bermuda Triangle like. I can see and select the fill it creates so I know the object is in the wall and building sections and it shows correctly on the plan. I hadn't changed the object's parameters nor those for the sections but checked them anyway and they look fine. I also tried closing down ArchiCAD and reopening the file, but no joy. How can I fix this problem?
- They disappear in section occasionally for no reason, usually when you are trying to get work out the office!
2009-03-02 09:29 PM
Josh wrote:The technique that seems to work for me (until it happens again ) is to move the section by a set distance on plan, open the section so it regenerates to display its new position, then move the section back again to its original location and open it again.Cons and things to watch out for.This is the problem I am having except in ArchiCAD 12 ... all the cut lines were gone... How can I fix this problem?
2009-03-02 10:01 PM
