Complex profiles and fills merge
Is there a way to keep two fills that are the same and that touch each other from merging together? I'd like to be able to see the line between them in some things I've tried to do and can't figure out how to do it short of adding a line later.
Thomas Holm
Use two fills that look the same but have different names (i. e. "empty fill" and "blank fill" - just clone one and rename the copy).
Works great! Thanks Thomas.
