DGSketcher
Legend
Composite Skins - A cautionary tale
Following discussions with GS UK it would appear that although you can insert a skin with zero thickness in a composite wall the consequences in AC21 can be unexpected. I added one as a vapour membrane which needed to appear in the skin list label but technically had minimal thickness so a value of zero made sense.
In my case I was getting core dimensions changing to non core locations when adding or removing other skins, the section display was missing fills and in 3D part of the wall was missing.
I have suggested that GS need to fix this so that you can't enter a zero value but in the mean time always check a skin has a thickness!
2 Replies 2
Titiriga
I also find that 0 thickness composite skins would be very useful. it would be much appreciated if it would become possible in the future.
Thanks.
Tim Ball
I find that thin skins in composites work quite well and show up better in detailing.
I also use the ability to change the linetype and colour that separates skins.
In the example attached there is a membrane skin and also a vent indicated using two fills adjoining separated by an arrow linetype.[img][/img]
Tim Ball
AC26, iMac
User since V5
