Showing results forย
Search instead forย
Did you mean:ย
Search instead forย
Did you mean:ย
Composite wall to a favorite.
I created a wall in the composite elements section of archiCAD and am now trying to make it a favorite, so that I can use it. How is this done? It seems like I cannot access it from the normal wall tool so that it becomes my default wall. Thanks in advance for your help!
1 Reply 1
Rick Thompson
There are 2 ways, one from the tool pallet, or directly from the favorites pallet.
Favorite pallet - select the preset wall, from fav pallet select save. Then, it should show up in the fav under that tool.
From the tool.. at the top of the pallet it has a button.
Don't forget the help menu.. it will tell you the same stuff:)
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
