Pete
Constrained input using [shift]R not allowed in AC9?
Old habits die hard! My favorite method for inputting or editing elements was to click the start point and then [shift] to constrain the angle, tap the R and type the distance. This does not work in 9.
Since nobody else has mentioned it, y'all must be using a better/different method. I must be missing something very basic here.
I am trying to use relative coordinates X and Y but it is clumsy. Help!
Pete Read
ArchiCAD 12; Artlantis Studio 2
MacBook Pro 2.4 Core2Duo, 2GB, OSX(10.5) and XPpro(SP3)
2 Replies 2
Works fine for me, Pete ... sounds like the Shift+R key combination is redefined in your shortcut scheme.
In WE, Keyboard Shortcuts, try to assign Shift+R to anything ... and the "Currently assigned to" box will show you if it is mis-assigned (or unassigned). It tells me, correctly, that it is assigned to "Radius (Global)". Cancel out before you really re-assign it of course.
Alternatively, display your scheme in your browser as shown in the attached screenshot, do a find (ctrl-F in IE) and enter "Shift + R" without quotes but with spaces to see what it is assigned to (or maybe it isn't assigned to anything anymore)...
HTH,
Pete
Thanks Karl!
Shift+R was unassigned in WE. Although R was assigned to "radius", it would not lock to the mouse constraint using the shift key. So I assigned the Shift+R in addition to R for the radius and now it works.
Regards,
Pete Read
