Copy Objects
In Version 7.0, you had the options to "Drag a Copy" and "Mirror a Copy", these seem to have disappeared in Version 8.1.
What I would like to achieve, for example: "Mirror a Copy" of a window around the mid point of a wall.
Perhaps these options have been replaced with another command?
Many thanks
Lucia
ArchiCAD beginner.
5 REPLIES 5
Aussie John
go to preference- miscellaneous and check the relevent box.
Alternatively (and better) hold the option key down during the non copy transformation and a copy will occur.
Cheers John
[/size]
Thanks Aussie John for the quick reply!
The check was missing from misc. and is now working as before.
"Option Key" is that for a MAC? I'm using a PC, is the "Control Key" the equivalent?
Aussie John
yes is for Mac- start your drag or mirror and before commiting it with enter then press your alt key( experiment) and a little plus sign if you have hit the right key
Cheers John
[/size]
Link
Don't forget to mention that this is a toggle, and that you can use ctrl+alt for multiple copies! Just double click to finish the command - and no you won't copy two on top of each other doing that!
For greater speed, you don't even necessarily need to hit ctrl+D - best used with the arrow tool, just click on your selected items and start dragging them. Then have at the ctrl and alt keys all you like!
Link.
Thanks for all replies and suggestions, they all worked well.
Kind regards,
Lucia
