martin-b
Copy Parallel Projection view from one file to another
Is it possible to copy a Parallel view from one file to another? I know that you can copy Perspective views with the help of a placed camera, but can you do something similar also with Parallel views? I know that I can match the settings for the projection manually, but I would like to be able to match also the contents of the viewport.
0 Replies 0
