Copy / Paste in word
Hello
When I copy/paste from Archicad to word or any other soft nothing happens
I can only copy paste on to Archicad
I m on Archicad 16
Windows 7 64bits
4 REPLIES 4
Erich
Assuming you are trying to copy/paste text and not something else. Select the text block and then start editing it. Once in the edit mode, you can select the text desired and perform the copy command. This will then paste into your Word document without issue.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Thanks Erich for your answer but I'm trying to copy/paste a 2D plan of a house and the command won't work. I tried copying anything and still the same nothing happens!
By default selecting and copying in Archicad does not copy info to your windows clipboard.
It is an internal Archicad copy only.
The best and easiest way is to use a screen capture program.
Otherwise there is a Registry setting that will make Archicad copy to the clipboard as well.
See this old post ...
http://archicad-talk.graphisoft.com/viewtopic.php?p=173408
The registry path is a little different now as it is in "ARCHICAD-64" rather than just "ARCHICAD".
I haven't tried it since back then as I just use a screen capture program.
Hi Barry and thank you so much for your help!
Your previous post below worked fine for me!!
Thanks again
There is a Registry entry called "copy to picture also" found here in the registry .....
[HKEY_CURRENT_USER\Software\Graphisoft\ArchiCAD\ArchiCAD 13.0.0 AUS R1\Input]
You will need to adjuast that path to suit your version of the software.
Set this registry value to "1" an now youcan copy and paste images.
