Cover fill
Cover fill for a ceiling grid - why can't you snap to it to locate light fittings?
8 REPLIES 8
In that case it would be nice, but imagine trying to pick something out of the sea of hotspots that would be created by other fills. It would have to be something you could turn on only when desired.
Laura Yanoviak
This was a frustration in ACAD.
meapl: Just set the Rotated Grid to the origin of the fill (and the grid snap to the grid spacing (e.g. 2'-0" x 4'-0" for 2x4 ceiling tile).
You could accomplish the desired snap by setting you user origin to the same location as the cover fill origin. Then use Archicad's snap feature with a 2'x2' grid (or whatever corresponds to your cover fill)
Laura Yanoviak
True. I guess I'm not used to working on orthogonal buildings...
Same concept except yours would apply to all situations - so it's the better response. The important thing to note here is that there's often a method to achieve the functionality you might be looking for (ie snap to a ceiling cover fill) but it might require some creativity and using all the of the tools available to you.
__archiben
then you are clearly your own worst enemy!
(rotate your grid . . . )
~/archiben
b e n _ f r o s t
Laura Yanoviak
I didn't say I designed the buildings...
Oh, I rotate my grid quite often!
Does moving the user origin move the origin of the grid snap? I thought you needed to set the [rotated] grid in order to do that?
__archiben
you do . . . and i should have read further up the thread and seen that you already recommended it. thought you were in need of an answer . . . my bad!
~/ben
b e n _ f r o s t
