‎2008-04-02 12:38 AM
‎2008-04-02 12:42 AM
‎2008-04-02 04:25 PM
Matthew wrote:This was a frustration in ACAD.
In that case it would be nice, but imagine trying to pick something out of the sea of hotspots that would be created by other fills.
‎2008-04-02 05:45 PM
‎2008-04-02 06:10 PM
Dom wrote:True. I guess I'm not used to working on orthogonal buildings...
You could accomplish the desired snap by setting you user origin to the same location as the cover fill origin. Then use Archicad's snap feature with a 2'x2' grid (or whatever corresponds to your cover fill)
‎2008-04-02 06:38 PM
‎2008-04-02 11:17 PM
Laura wrote:then you are clearly your own worst enemy!
‎2008-04-02 11:25 PM
~/archiben wrote:I didn't say I designed the buildings...
then you are clearly your own worst enemy!![]()
~/archiben wrote:Oh, I rotate my grid quite often!
(rotate your grid . . .)
‎2008-04-02 11:30 PM
Laura wrote:you do . . . and i should have read further up the thread and seen that you already recommended it. thought you were in need of an answer . . . my bad!
I thought you needed to set the [rotated] grid in order to do that?
