Create new stair method
I used the create new stair method instead of one of the provided stairs in order to get the desired reflection of the stairs on the next layer but now I can't seem to change the line weight of my 2d stair. Any suggestions on which value to change?
you mean in stairmaker?
if yes :
when you complete the stair and then save it , ac returns you in the stair window. there under floor plan and section tabs you select the desired line weights
make sure you uncheck the two first boxes
if you dont use stairmaker:
tell me which program you use
hope i could help
Thank you Wendy, that seems to have resolved my issue.
