Create new windows
I'm still not familiar with creating library parts, doors, windows, etc. in AC 8.
I've drawn my new door lying down with slabs, and now I'm looking at it in my 3D window from a parallel side view at 90 degrees... How do I save that as my door? Is it a GDL object?
10 Replies 10
"Ben Odonnell" wrote:
"Luc_M" wrote:
I
Please not if the door is an odd shape you will have to go into the GDL script and play with the wallhole command..
The easiest way to remedy this is to make a slab the shape of the whole required, save it (from same coordinates as door/window). Save as an object select the 3D info and copy and paste it to the wallwhole command, delete the slab object when done with it.
