‎2008-12-03
11:55 AM
‎2023-05-25
04:56 PM
Rubia Torres
‎2008-12-03 06:27 PM
‎2008-12-04 04:21 AM
‎2008-12-04 01:59 PM
‎2009-02-11 05:05 PM
‎2009-02-11 05:21 PM
Hence wrote:This is just BS. If you really do redraw everything in 2D like you say, you simply don't know how to use Archicad. As Djordje points out time after another, lack of knowledge is Archicad's greatest problem.
If you have to redraw everything you build in 3D in 2D to make construction documents, than it is just a wast of time. I am finding that you have to do this with everything,
‎2009-02-11 05:52 PM
‎2009-02-11 06:58 PM
‎2009-02-11 08:30 PM
Peter wrote:I'd just like to emphasize what Peter is saying here. There is simply no need to redraw anything manually unless you want to add something that
Now, wall sections. The best way to use ArchiCAD is to physically model things to a level that you would see on a 1:50 drawing.
Peter wrote:Again, what he says here applies to details, not section or plan views. Simply since it's usually a waste of time to model details.
In a detail, it is often best to copy the lines & fills extracted from the model off to one side, and edit these to look presentable.
Peter wrote:Once more, this is so easy, if you just use the Quicklayers palette and the Layers/layer combinations dialog.
And yes, you will have to create a few layer combinations,
Hence wrote:You're right there. Your office saved a couple of bucks on proffessional training. Now you're losing thousands because of that decision.
To start, you are right. I have not received training on ArchiCAD and that is 90% of why i don't know how to do things
Hence wrote:Your office's QA routines must be a mess too! I hope none of your clients are reading this. Or rather, I hope they do!
My office has just found it eaiser to copy the view over and re draw the copy, which is now a mess of lines and empty fills.
Hence wrote:Archicad does too. When you've finished controlling visibility in a view with the Quicklayers palette, it takes about three seconds to save the layer combination, and three more to save the view's settings. (Note: for efficiency, this is not what I recommend - I'd rather re-use the same layer combo for several views, but if that's what you want, you can have it.
Revit allows you to control an objects visibility and line wt per view
Hence wrote:From what I hear, to use Revit efficiently requires training too. I hope you made a better decision regarding that program or I'm afraid, in a few years, when the majority of architects have learned what BIM really can be, you'll be out of business from pure inefficiency!
You can say that it is bs when the majority of architectre firms do NOT use this program.
‎2009-02-11 08:59 PM
