Brad Elliott
Creating a splayed column
I can't believe I haven't done this before or can't figure out how but I want to create a splayed (double pitched) column. Please see the enclosed plan view. What is the easiest way to do this?
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
12 Replies 12
vfrontiers
Initially I thought to use a roof and adjust all the edge cuts individually. No sure you could get exactly this.
But, if your up for creating an object, I think its the RULED form you are looking for. With the top and bottom the same "plan", should be pretty simple.
Also, I suppose you could try a simple COLUMN (tool, not an object) and use the Z rotation to get it leaning. You probably have to SEO the top and bottom if you want them level.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Or your could create a complex profile with the rotated section...
HTH.
Brad Elliott
OK I still can't figure out how you made that complex profile. I can still only get rotation one way.
M1 Macbook Pro
Imagine drawing a "diamond" as the complex profile. The rotation initially would be one way, but after you rotate the object around the z-axis, it will appear as a double rotation.
Richard
AC26 (since AC6.0), Win10
Dwight
Great solution!!!
All complex profiles come from the Greek.
Dwight Atkinson
Brad Elliott
Now thats some skewed thinking.
M1 Macbook Pro
Glad I could 'splayn it to you.
Richard
Brad Elliott
And it doesn't even need to be a complex profile. Just take a regular old column rotate it and then rotate and tilt..
M1 Macbook Pro
Dwight
That IS correct, but you can't compensate for lateral distortion caused by the tilt angle of the column using a square section.
Dwight Atkinson
