Cropped Composite Dropdown
Andy Melaragno
Hello,
I'm not sure if this is a bug or not but my composite drop-down menu is cropped so that I can only see part of the composite name (see attached picture). To be able to see the entire composite name I have to open the composite pallet and it lists the full name of the selected composite at the top of the pallet. Do I have a setting off? Does anyone else have this problem? If so, are there any work around? It is happening on both AC22 and AC23. It's not a huge problem, it's just annoying.
Thanks.
Andy Melaragno
Columbus, Ohio USA
AC 24 - 27 USA | Windows 11 Pro | GeForce RTX 2060 Super | 32 GB |Intel i7-8700K @3.70 Ghz
1 REPLY 1
Yes that is normal.
You will find the same with surfaces as well.
