Curved bar/rod
How can I make a curved/radius bar or rod?
4 REPLIES 4
Sorry I've solved it. Objective Duh!
You could use a complex profile with a curved wall but you will not get a truly round profile if that is important to you.
Or do a search in your object settings dialogue for 'curve' and see what objects pop up.
I am sure there are a couple of curved tubes or bars in the default library.
Or of course you have the morph tool.
Thanks Barry, I just cannot do that with the morpth, I did see a tut on Youtube, but it is not easy to do.
