2026-10-01 11:59 AM
Hi. The wall connection curved-straight is buggy. I can change the curved segment to a poly wall but then I need to use Basic material and the 2D is different from the regular wall. Any clever trick aside from poly wall and a patch?
Br,
Mats
a month ago
Which version is this? I've never seen an artifact like that with round walls. 😮 I'm not sure what's going on there.
You should send this file to support tho, so they can fix it.
a month ago
The only time I have seen this issue is when the junction between walls is not tangential to the associated curves... They are radially intersected right?
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
4 weeks ago
27...I asked the support and it's a bug...some radiuses are rouge in Archicad ...I've had the same behaviour with a simple fill many years ago. We can solve this by making the wall a poly wall... not a Bimmy way to do it though..
