Mats Knutsson
Curved wall bug...any way to fix?
Hi. The wall connection curved-straight is buggy. I can change the curved segment to a poly wall but then I need to use Basic material and the 2D is different from the regular wall. Any clever trick aside from poly wall and a patch?
Br,
Mats
HP ZBook Fury 15,6 G8. 11gen i7-11800H 2.3GHz. 32 GB RAM. Nvidia RTX A3000 1GB. AC22-27 SWE.
3 Replies 3
runxel
Which version is this? I've never seen an artifact like that with round walls. 😮 I'm not sure what's going on there.
You should send this file to support tho, so they can fix it.
Lingwisyer
Guru
The only time I have seen this issue is when the junction between walls is not tangential to the associated curves... They are radially intersected right?
Mats Knutsson
27...I asked the support and it's a bug...some radiuses are rouge in Archicad ...I've had the same behaviour with a simple fill many years ago. We can solve this by making the wall a poly wall... not a Bimmy way to do it though..
