Cutting or trimming beam
Enclosed is a picture, maybe someone can help... Not sure if trimming or if there is another object I can use to trim to or what
13 Replies 13
Even though it seems relatively easy, I am new to Archicad and I don't quite understand what is going on. Can you give me an easier breakdown?
1. Draw a slab the exact shape of an elevation of your beam
2. Select the slab, go to 3D view. Select an Axonometric view, not perspective.
3. Go to 3D projection settings, select the side view icon ( 1 - see attached) and move the camera icon directly above the house (2).
4. Go to File>GDL Objects>Save 3D model as... and save your object to the desired location.
5. Select the Object tool and your newly created object will be the current selection, place it accordingly in your plan.
... I think.....
I did it! Thank you guys so much! I can't belive how incompetent I am.
TomWaltz wrote:
whoa, BIG cylinder.
Think big, act big!
Well, I must admit this was now the best example of using SEO.
Tom's decission is best for beginners, I just overlooked it!
