DRAWING NOT SHOWING IN PLOTMAKER LAYOUT
The imported drawing in layout only shows up as a frame. Checked in Drawing Setting, and it's not in "frame only". Update numerously times. Still getting a frame only. Any ideads?
__archiben
putting your archiCAD version and machine specs in the post might help narrow things down a bit.
first thing off the top of my head: there was a bug in the plotmaker 9 whereby a drawing wouldn't update from a PLN view if the PLN was open on another machine across the network.
http://www.graphisoft.com/support/archicad/archiguide/LBKupdate.html
not sure if it got nailed in 'hot-fix 3' either, but if you haven't patched archiCAD be sure to go Help>Check For Updates...
~/archiben
b e n _ f r o s t
Have you moved drawing contents? If not checked as "fit frame to drawing" in PM view you might be looking at a blank view (as AC/PM9 can redefine actual view)
