Learn more
Louzille
Design options
Does the design options work on solo or only the full version? Since it can be used in hotlinking, which is only available in the full version.
1 Solution
sknsnw9
I have a Solo version and we do have Design Options.  We don't have hotlink or teamwork.
Archicad Solo 24 - 28 : Windows 10 Pro 64-bit : 16 GB ram / Intel Core i7-4770k @ 3.50GHz : NVIDIA GeForce RTX 3060 / MacBook Pro M3 Max
Go to post
4 Replies 4
I can't find a list of what SOLO does or doesn't include.
But if it is anything like START, that does not have hotlinking or design options.
It would be best to contact your local reseller though.
https://graphisoft.com/contact-us
One they can tell you the answer.
And secondly they should be able to tell you if the SOLO version will be available in the future.
It seems that the START 24 version will be the last according to this post made just yesterday.
https://community.graphisoft.com/t5/Graphisoft-Insights/Archicad-Start-Edition-2024-release-and-impo...
It is unclear from this if SOLO will have the same fate.
jl_lt
Ace
Very unsettling news indeed
vistasp
Ideally, Solo would be everything except Teamwork, but I don't make the rules. 😅
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
sknsnw9
