Design toolbar is missing
I use AC11. I need to make use of the trussmaker tool, but i dont have the design toolbar, or the trussmaker tool anywhere. I looked in 'work environment' and neither are there.
Any ideas
15 Replies 15
Link
Add it.
(There - my reply was shorter!)
Link.
Im not sure how to add something that doesnt exist
Link
If the add-on is loaded, then it does exist. You're just having some trouble seeing it for whatever reason. Try adding it to a menu.
Link.
I found it but i cant select it and add it
Link
You will probably have to create a menu called TrussMaker and add the individual commands to it.
Link.
Link.
Finally something that works
Thanks for all the tootledge
