Dialog Box not stretching
The Edit Database dialog box seems to conceal some functions, and is not stretchable like all other dialog boxes. Any ideas what might be the problem?
In the edit database, when selecting a key, the dialog box shows 3 inputs: database, code, name and is the appropriate size. If I select a component, the dialog box size does not change, and shows 3 inputs: code, name, and the quantity box is partially shown. I assume there are additional inputs that should be visible below that. I am unable to manually stretch the box by grabbing the border.
I am running using ArchiCAD12 with Windows xp.
0 Replies 0
