Too Long
Dimensions changing when updating
Hi all.
Ive had this happen a number of times and would like to know if this is a bug.
With layouts set to Auto-Update the dimensions change to illogical locations.
Once updated again they change back to the correct locations.
The below GIF starts with the dimensions incorrectly displayed. Prior to this they were correct until I updated the layout, this is where the GIF starts.
AC26 AUS Full
DGSketcher
Legend
@Too Long Unfortunately it is a known problem that shouldn't exist and GS are trying their hardest to contain it. The problem stems, as you have shown, from different plan views that have the same dimensions being present in those views. When associative nodes disappear AC has a choice of deleting the connection or hiding it so it can be restored. The latter is the current strategy. I have been stung / embarrassed by this too many times, the only user option is to double check views and possibly work with the manual update option or possibly (I haven't verified this) create a layer for dimensions per view.
Too Long
Thank you very much for your response.
AC26 AUS Full
