krusty
Does anyone know why when i put things on plan they are not showing in 3d model?
There is a chance that clicked smth im settings and now its not working. All i can tell is that it changed in a moment when i hide one layer and then i tried to bring in back and in did but also this problem appeared. So rn i need to put all the furnitures and walls in 3d model bcs the plan doesnt let me
Xandros
try the shortcut Shift + 3 to show everything in the 3D
or check your Filter and Cut Elements in 3D Dialog Box
ArchiCAD 27 GER / Win10
Intel i9-9900K / 64GB RAM / nVidia GeForce RTX 2080 Ti
aarkell
In addition to Xandros' comment, you can also try the shortcut ctl+alt+a, and set your story settings to infinite, so that you can see all stories, just in case you have your story settings limited to a select few.
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
