ā2023-11-27 10:22 AM
There is a chance that clicked smth im settings and now its not working. All i can tell is that it changed in a moment when i hide one layer and then i tried to bring in back and in did but also this problem appeared. So rn i need to put all the furnitures and walls in 3d model bcs the plan doesnt let me
ā2023-11-27 10:29 AM
try the shortcut Shift + 3 to show everything in the 3D
or check your Filter and Cut Elements in 3D Dialog Box
ā2023-11-27 08:24 PM
In addition to Xandros' comment, you can also try the shortcut ctl+alt+a, and set your story settings to infinite, so that you can see all stories, just in case you have your story settings limited to a select few.
