Dome Curtain Wall?!
Is it possible to make a Dome Curtain Wall and if so, can someone please explain? Thank you in advance!
5 Replies 5
Dwight
Making a dome with ribs and glass [This technique is highly editable, relying on, no surprise, the complex profile as a wall tool creating two related profiles].
1: Draw a circle to the dome diameter
2: Get the dome radius
3: activate the Complex Profile, open the edit window.
4: draw 1/2 the dome as an arc
5: Copy the arc, paste the arc [original location] shrink one arc about 2"
5: Magic wand a line against both arcs using the magic wand 'segments along arc + linear segments' constraints to establish the number of flat panes.
6: delete the arcs
7: Close off the top and bottom of the segment to contain a fill
8: Magic Wand a fill into the space. Tell it to be glass.
9: Using a different fill, draw muntins at the pane edges. Tell them to be metal.
10: Copy all. Store the profile.
11: Paste into a new profile edit window. Use original location constraint.
12: Draw the mullion section. Metal. Store.
13: Return to the plan view.
14: Set up the glassandmuntin section in the wall tool
15: magic wand the wall to the circle [linear segments, as many as needed, say 24?16?]
16: switch to the mullion section in the wall tool
17: draw a mullion width wall radiating from the center to edge
18: When satisfied of its orientation [until you get good at this, the wall often draws backwards] multiply the mullions around the circle.
19: Play the viola. You are done.
Dwight Atkinson
very nice dome done but i was wishing that you can explain it by images with every step so i can follow easily or with video
Cheers
Dwight
keep wishing.
Dwight Atkinson
Do not be sad from me Dwight i appreciate your effort thanks anyway for your tips you provided and i apologized if i un estimate your help
Dwight
The solution will be obvious if you play with:
Magic Wand Settings.
Complex Profile.
Dwight Atkinson
