Door Casing location in 2D different then 3D
Josh Griffen
See the attached photo. Per the door settings, I have the casing overlapping the 1" door frame by 1/2", leaving 1/2" of the door frame visible. This looks correct in Elevation and 3D views. However, in the floor plan the casing is located 1/2" outside of the door frame, leaving a gap between the frame and the casing. Is this a bug or is there a setting for the casing 2D location somewhere else?. Thank you.
Archicad 22
Windows 10
2 REPLIES 2
David Maudlin
Josh Griffen:
I do not understand the logic, but look at Door Settings > Arch Top Door Settings > Floor Plan and Section > Show Reveal on Symbol > Always puts them in the correct location, Never moves them out.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Josh Griffen
Thank you! You can also change it in the MVO settings so it is universal.
Archicad 22
Windows 10
