Door Openings
Im having some problems getting the wall ends to show adjacent to doors.
Im trying to do a reflected ceiling plan so have set the model view to show openings only no contours.
On the plan, some of the door openings have wall ends, some don't.
It is something to do with the composite settings - my stud walls are fine but my block ones aren't.
I cannot fathom out what setting to change.
Wall settings - wall end lines set to both.
In composite the 'Use skin end lines' box is ticked.[/img]
I've tried to add some pictures but not sure if the add attachment thing has actually work.
Advice greatly appreciated.
Regards,
Tom.
0 Replies 0
