Door/Wall issue...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-07-08
08:51 PM
- last edited on
2023-05-25
05:49 PM
by
Rubia Torres
2009-07-08
08:51 PM
5 REPLIES 5
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-08 09:28 PM
2009-07-08
09:28 PM
From your image it looks like you have modelled two separate walls. A solution would be to place an empty opening into the lower wall which is the same size as the door needs to be.
Using a multistory wall in place of the two separate walls would work in this situation as well.
I don't understand why the floorslab is showing in this position though? Surely there would be no slab in the position of the stairwell/corridor behind the door?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-08 09:33 PM
2009-07-08
09:33 PM
They are two separate walls, yes. I was just wondering if there was a setting somewhere that would "pop" the whole door out.
If I use a multistory wall, won't the windows on both the floors show up on both the floor plans??
Don't mind the floor slab not supposed to be there!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-08 09:55 PM
2009-07-08
09:55 PM
Steven wrote:No, not at the moment.
If I use a multistory wall, won't the windows on both the floors show up on both the floor plans??It all depends on the projection/symbolic settings of both the wall and the door, and whether the door intersects the floorplan cut plan. What floorplan would you normally show a door that's halfway in between floors?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-08 10:00 PM
2009-07-08
10:00 PM
Peter wrote:This one is more on the second floor so.....
I never though of using one tall wall for two stories and just using the floorplan cut plane to show certain elements. I always used two walls.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-07-09 06:54 AM
2009-07-09
06:54 AM
Steven wrote:As I do too.
/..... I always used two walls.
KISS principle Steven, just put and empty opening in the wall below.
Rod Jurich
AC4.55 - AC14 INT (4204) | | OBJECTiVE |
