Doors Problem
The doors are extruded and i can not change the height of them. I can only see them if I change the projection option in 2D. But in 3D it is not working (see pic.)
3 Replies 3
David Maudlin
alpcaliskanturk:
It looks like the Doors are not positioned in the Wall (if that is the host Wall shown in your screen shot). Check the Anchor point of the Door under Door Settings > Preview and Positioning.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you for your comment. I just checked the Anchor point and tried every option, still not working. If i try to select the door in 3D view, it select the whole wall.
David Maudlin
I would see if the Wall and Door have the same Home Story, then try anchoring the Door to the base of the Wall.
I cannot reproduce this, so there may be a deeper problem with the elements. It may be best to redraw the Wall and add the Doors.
Thanks for adding the signature.
David
