2007-10-18
09:00 AM
2023-05-23
05:04 PM
Rubia Torres
2007-10-18 12:02 PM
2007-10-19 01:53 AM
2007-10-19 01:59 AM
2007-10-19 02:18 AM
2007-10-19 02:23 AM
2007-10-19 03:45 AM
2007-10-19 04:30 AM
gerald wrote:I know your problem - happens in AC10 as well.
OOPS!
got waylaid by work in hand and didn't finish the post...
The problem is:
After click-dragging and hitting ctrl, i get a + until the object is approx. 50pix away from it's original position, at which point the + drops off and a copy isn't made.
Hitting ctrl again after that seems to fix the 'drop-off' permanently for that drag only.
2007-10-19 06:12 AM
The trick is drag an let go of the mouse button then press CTRL....alas it is not..
I hope this is the solution to your problem.
