Dynamic blocks equivalent
Hi, is there something similar to what Revit has known as Dynamic Blocks? I'm not entirely familiar with it, but as far as I understand, you can, for example, have 1 type of house repeated several times, make changes to one of them and all the others change too, so you don't have to delete every other house and copy/paste all over again. Anyone knows if this can be done somehow in archicad?
Thanks
3 Replies 3
sinceV6
Hi.
Look into Hotlinks.
Best regards.
Yeahm I just found out about those thanks a lot!
Hi everyone!
I'm having a problem with this feature, maybe my little knowledge about the Hotlinks:
I'm also working with houses and I need to place same houses all over a terrain. When I move them in height (in the 3D), the floor plans are not displayed correctly anymore. The view "cut" is made in the physical height, but I would like to display in such a way that we would show all the "first-floor elements" in the first-floor view.
Is that possible? Maybe some kind of locking or display options?
Thanks a lot in advance for your help and time to all.
