2022-08-31 09:53 PM
HI everyone,
Just wondering if there is a new feature / toggle for selecting elements in the 3D window in Archicad 25.
Whenever I go to select elements in the 3D window, the selection tool highlights/chooses a non-visible element BEHIND the element that I am trying to select. Definitely useful but not always. I don't recall this in earlier versions - is there a way of turning this on/off?
Thanks
2022-08-31 11:01 PM
Doesn’t pressing the tab key cycle through the potential selections so that you can select the correct (highlighted) one?
2022-09-01 03:06 AM
Or activate the tool for the element type you want to select, then SHIFT select that element.
Again TAB if there happens to be multiple overlapping elements.
