Elevations
How do I get the lines from interior columns(in walls), floor slabs to not show on my 2d elevations or 3d model for that matter? See attached drawing.
Another question: Is there way to have elements in a floor plan like walls that extend two stories show on the 2nd floor. floor plan, that is not in the ghost story?
4 REPLIES 4
Make sure the columns are flush with the wall and the surfaces have the same material.
No you cannot show walls over different stories (a wish that is talked about often here). Either draw walls on both stories, or if you have tall windows, as in an atrium, draw the lower wall full height and use lines and fills to imitate wall on upper level.
Aussie John
sng
if you go into your double/triple post you will see an "X" in top right(?) corner. Click to delete them if they are redundant. As long as no one else posts you will be able to delete the thread
Cheers John
[/size]
I am not following you? Could please be more specific?
Aussie John
Sure, You have posted the same questions in a number of different sections. there isnt a need to do this, and is undesirable, so i am suggesting you delete the duplicates.
You should be able to go the duplicate thread and click the "X" mark to delete. ( unless the feature has been removed recently)
cheers
Cheers John
[/size]
