Haneef Tayob
Entering special characters
Hello
Not sure if there is a workaround or something else I'm missing.
Previously in AC8.1, when I needed to type in a special character such as degree or square, I would simply type in alt-0178 or any of the other character codes. I could also copy/paste from the windows 'character map' if I could not remember the code. Pasting from the 'Character map' was however a slower method.
Now in AC9, with it's updated text functions, I have to use the tedious 'character map' paste method.
Is there still a way to type in the special characters (using alt-0178 for example) or do I have to add it to a wishlist for Grapisoft to reintroduce.
regards
Haneef
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
5 Replies 5
__archiben
b e n _ f r o s t
__archiben
by the way - the degree symbol is usually accessed by pressing ALT and the zero key together, and the square root sign by pressing ALT and V together. the following screenshot was made by holding down the ALT key and typing all of the characters on the keyboard. you could always remember the ones you want . . . and anyway, isn't ALT-0 easy than ALT0178?
archiCAD doesn't support some of the unicode characters, so you may find a few missing from the full set . . .
cheers!
~/archiben
b e n _ f r o s t
Haneef Tayob
Dear Ben
Thanks for the reply.
The suggestion of adding the special characters to ones favourites however only applies to the mac version of ArchiCAD (I unfortunately did not mention my platform as being pc in my initial message)
The use of the shortcuts (alt-0189, etc only seems to be disabled in the text box, as I can still use them in custom dimension text, etc.
regards
Haneef
Haneef Tayob
__archiben
but have you tried just using the modifier keys as i suggested? what does ALT and 0 (zero) produce when you type them together in the text edit palette?????!!!!!
~/archiben
b e n _ f r o s t
I am on a PC and the ALT and 0 (zero) and the ALT and V, do nothing....
