Error Messages in AC
We are new to AC and are working on a project using teamwork. Everytime we open the file AC generates errors. The errors are as follows:
WARNING: While opening the file
1. Duplicated database name "AC_8_US" at line 1 of file MASTER_GDLAC_8_US.gdl.
repeated 6 times
Report:
We are also getting errors while switching from 2D to 3D. These errors are below:
WARNING: While switching from 2D to 3D.
1. Polygon is degenerated at line 577 of file wa_trim_us 81.gsm.
repeated 7 times
Report:
Polygon is degenerated.
Can't find Macro: D Saracenic Opening, called
at line 205 of file sri monument2.gsm.
Can't find Macro: sri, called
at line 319 of file sri monument2.gsm.
at line 335 of file sri monument2.gsm.
at line 351 of file sri monument2.gsm.
at line 367 of file sri monument2.gsm.
at line 383 of file sri monument2.gsm.
at line 399 of file sri monument2.gsm.
at line 415 of file sri monument2.gsm.
at line 431 of file sri monument2.gsm.
at line 447 of file sri monument2.gsm.
at line 463 of file sri monument2.gsm.
at line 479 of file sri monument2.gsm.
at line 495 of file sri monument2.gsm.
at line 511 of file sri monument2.gsm.
at line 527 of file sri monument2.gsm.
at line 543 of file sri monument2.gsm.
at line 559 of file sri monument2.gsm.
at line 575 of file sri monument2.gsm.
at line 591 of file sri monument2.gsm.
at line 608 of file sri monument2.gsm.
There are several problems with this file. You can cancel the operation with Ctrl/Command - period.
Document name : Untitled
Processed : 238 walls 127 objects 6 columns 0 ncBeams
38 slabs 0 meshes 32 pitch roofs
Start time : 5/3/2005 4:07:45 PM
End time : 5/3/2005 4:10:31 PM
Elapsed time : 2 minutes 46 seconds
Projection : Custom axonometry
Camera azimuth : 7.09221
Start time : 5/3/2005 4:10:31 PM
Elapsed time : 0 seconds
Any help on what needs to be done to correct these is most welcome.
Thanks!
15 Replies 15
archiben (sorry, my tongue kinda trips over the ~/)
Things seem to be back on track now. I did remove those items from the library and then close out and reboot but, to tell you the truth, my Library Manager looked just like yours. Then, when I reopened ArchiCAD, I checked the default boxes and it opened without any report or warning. I think there was something amiss in the Recent Project Settings that I was able to avoid by returning to the default.
Many thanks all. I realize I have much to learn and look forward to the adventure. And when I figure out this picture posting thing I may be dangerous.
Thanks to all of you. We were able to resolve a lot of th eerrors. Now we are getting only two errors. The first is when we open the file and the secod when we switch to 3D view.
The error message we get is:
How do we ot about handling this?
Thanks!
__archiben
i don't have the US library, so i can't delve into this object and see which parameter is being worked on at line 577 - maybe a US user could look into this and post?
as far as what's happening: this is a library part - most likely a window - that calls another library part (a 'macro') as a part of the script that generated it. the macro it's calling 'wa_trim_us 81.gsm' is responsible for generating the trims around that window. i would expect that somewhere in your project you have a couple of windows with their trims turned on, yet the parameter values you have entered for those trims are 'bad' (like a negative number or something).
if nobody using the US library replies to this, e-mail me your project zipped and in archive format (File>Save As... and choose 'ArchiCAD Archive Project' as the file format) to the address in my signature below and i'll have a look . . .
HTH
~/archiben
b e n _ f r o s t
Hey Ben,
The file size is around 20mb. Can I still email it to you?
__archiben
no! have you zipped it?
also: make sure your 'save as archive' options resemble the attached screenshot:
~/archiben
b e n _ f r o s t
Thanks to all of you. We were able to solve the problem.
