ā2003-10-30 04:56 AM
ā2003-11-01 06:17 PM
Of course! I'm looking greatly forward to my next change of colour - can be considered as a hybrid caterpillar/chameleon evolutionary step, I guess ?!
The question is, Stuart, will your photo change color as you attain each new level? (I'm assuming your choice of 'green' was as in 'green beginner' ...)
Thanks for the flowers ... cheque is in the post!
At least all but the truly new members know you to be the expert that you are!![]()
ā2003-11-06 08:27 PM
ā2003-11-06 10:32 PM
ā2003-11-07 12:09 AM
ā2003-11-07 12:35 AM
chad.lawson wrote:You are right on target - why must we be limited - is it just plain old greed and no concern for the user?? which I think is the case. OR is there some other hidden agenda???? The big deal is the apparent "freebee" status of most of the distributions and not that one is better, etc.
<chuckle> I'm an avid Micro$oft Windoze user, so I know your frustration. It's pretty funny with the rivalries of Smackandtoss, and Windoze uzers. I feel that this analogy works best for any operating system. Let's say you have a shelf with 5 levels, on each level is a row of 10 bins, each with a label describing which series of Lego's is in each bin. Now if I were to ask you to get a red 2x6x2 red lego brick, you'd walk over to the shelf, searching through the bins, and in a matter of minutes you'd have the piece in hand. . .Now if you were one of our current operating systems, and I asked you to do the same thing, you'd walk up to the shelf, walk around it, then knock it over, spilling it's contents on the ground, then kick through the Legos with your feet, and bring me a green 2x6x2 brick after a few hours. . .
ā2003-11-07 05:39 AM
chad.lawson wrote:Or someone else can do something really
I guess if someone else came up with a really good OS we would still be stuck with the monopoly. Oh well I'll keep on banging the head against the virtual wall - - -
ā2003-11-08 11:49 AM
ā2003-11-10 09:49 AM
LewBishop wrote:I don't think so. The license cost of the OS is only a very small part of the total use cost. When you have your expensive employee losing time on an OS he/she is not familiar with, then you loose money.
ā2003-11-10 04:30 PM
stefan wrote:Perhaps the cost may be irrelevant, but using one vs the other is related to more than being forced to use one just because it sells the most. Equating that to CAD software is saying that we should only use Autocad because it sells the most. Neither argument makes sense to me. Finding and using the best tools is, for me, the solution.LewBishop wrote:I don't think so. The license cost of the OS is only a very small part of the total use cost. When you have your expensive employee losing time on an OS he/she is not familiar with, then you loose money.
If you can get your work done on a more expensive OS, then the cost of the OS is irrelevant. Even when you need 50 licenses.
ā2003-11-12 03:31 PM
