Exporting DWG to simple x y coordinate walls
Hi Everyone,
I am a newbie to ArchiCAD. I am looking to do a pretty simple transformation of my DWG file into 2D coordinates. Basically, I want to turn all my walls into a series of x and y points so that the file looks something like this:
31.150421471 27.316349377
31.375421957 27.316182046
31.180400275 39.260349377
31.005400275 39.260349377
31.005400275 39.312349377
31.180400275 39.312349377
31.180400275 35.660349377
31.005400275 35.660349377
31.005400275 35.712349377
31.180400275 35.712349377
31.180400275 32.060349377
31.005400275 32.060349377
and each two numbers represent a wall.
Is that possible with ArchiCAD?
All help much appreciated,
Thanks,
Kris.
Link
This is a bit of a stab in the dark, but have you tried saving as a DXF?
The beauty of DXFs is that they can be opened up in a text editor. I've seen guys edit entire DXFs in Notepad to change block names, then resave and whooshka, when they open it again all the blocks are switched out.
Anyway, I am guessing your wall data could show up and even be manipulated in the same way.
Link.
