FLOOR DECK MODELLING HELP
Dear All,
I am the new one using Archicad, and I am working with Archicad 21.
I have the matter while modeling floor deck with the shape as attachment.
Could you please help me to model it without using add-on .
3 Replies 3
mikas
With custom profiles would be an easy solution. Do a custom profile by drawing it with appropriate fills. These fills are each attached with a construction material. Save the profile with a name. Open beam tool, make it to use a custom profile you just made and draw a beam you had saved earlier.
You can mix profiles to achieve a net, for example. Just use another different profile, and draw it perpendicular to the previous one.
You can then later slice your beam(s) with Solid Element Operations (=SEO or =Boolean operator in some countries) if you need to. Just be aware of their priorities. Keep a higher priority with the cutting element, or it might not cut other elements.
I took a round part apart to demonstrate the stucture.
AC28, Rhino8+Grasshopper, TwinMotion • Mac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
Dear Mikas,
Thank you very much for your help.
I see in "profile manager: there are no SLAB in "USE WITH".
I can assign deck floor with Beam, but in the schedule, does it understand that is beam or floor? How could we make custom profile use with Floor/Slab.
I am new user Archicad so that I dont know it works like revit or not?
Thanks!
Aditional, How can I make an opening for deck slab above?thanks
