FOUNDATIONS drawn at 45 degrees
Question how to draw foundations at a 45 degre angle?
1 Reply 1
Hi, you can use beams to model your footings and create custom profiles for custom shapes if you need that. Beams can have angles and will join the horizontal ones.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
