Ekliptikan
Favor: convert .pln to .skp
Hello! I don’t have Archicad unfortunately, but I need to open this model in Sketchup. Could someone do me the favor
of converting it for me? Thanks in advance!
1 Solution
The best way is to have your cousin save the file for you, after all it is his property.
Then there can be no confusion as to whether you have the rights to the file or not.
It should only take your cousin a matter of minutes to save it.
Go to post
3 Replies 3
This appears to be a set of plans (model) created by an Architectural or Drafting firm - Camex?
You should probably contact them and ask them to convert the file to ensure you have the proper authority to do so.
And if you do not have the proper authority for this file, you may want to consider removing the PLN from your post rather than sharing it with everyone.
Ekliptikan
Thanks for your answer Barry. Yes it's a building firm run by my cousin, since he didn't have time to do this for me, he gave me his blessing for asking for help. But I think you're right, maybe I shouldn't post my blueprints publicly, so I removed the file. If you have any tips on how to solve this, please let me know 🙂
