Favorites Parameters / Element Transfer Settings
Achille Pavlidis
Hi all,
I'm a bit confused with the Favorites Parameters. Has this been replaced by Element Transfer Settings?
I find a lot of Help pages like this: https://helpcenter.graphisoft.com/graphisoft-archives/54814/ this: https://helpcenter.graphisoft.com/user-guide/64891/ and this:https://helpcenter.graphisoft.com/knowledgebase/54163/
that refer to "Favorites Parameters" but they are nowhere to be found.
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
4 REPLIES 4
Podolsky
Ace
They are available via menu Window / Palettes / Favourites
Achille Pavlidis
Thats Favorites.
I was referring to Favorites Parameters
Yes, 'Favourite Parameters' has now become 'Element Transfer Settings'.
You can now set up multiple transfer setting schemes and can choose which one you want to use when you need to transfer the settings.
Your original post was over 2 years old, so I am assuming you have figured that out by now.
If not just yell and we will be happy to help.
Podolsky
Ace
You need to open this favourites panel (note that it's different from panels you can access in the tools) and press on small button with a gear. In drop-down menu select Element Transfer Settings.
