We value your input!
Fill behaving different in Plotmaker
the strangest thing!i have a 600x600 grid fill that is working perfectly in AC...mean moving its origin to a certain reference.BUT it maps differently in plotmakerThe lines are just not where they are supposed to be!WHY?
4 REPLIES 4
__archiben
how is plotmaker displaying the fills? bitmap or vector?
go to Options>Display Options and at the bottom ensure that the fills setting is to "Keep Original Settings". that way you should get what you see in archiCAD . . .
HTH
~/archiben
b e n f r o s t
thanks achiben for your quick reply.nothing going though.display is vectorial and even after checking keep original settings,no luck.Looks as if i got a bug here or what...i'm still on 8.0.could this be a bug that they fixed with 8.1?
image II.Fill in AC looks fine.
BTW,I just saved down to AC 7.0 and it is working well!
__archiben
i do recall an issue with 8.0 and plotmaker fills. think it may have been discussed here somewhere too.
UPGRADE!!! you won't regret it.
~/archiben
b e n f r o s t
