Fill problems
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-05-31 02:01 PM
‎2011-05-31
02:01 PM
For some reason in all my current projects solid colour fills show as white (invisible) - includes normal fills and cut fills of, say a wall on a floor plan.
In section view, however, I can see my cut fill normally.
If I make a new file using Archicad template - this issue disappears.
Starting from scratch would be too much of a hassle.
Any help would be appreciated.
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-05-31 03:32 PM
‎2011-05-31
03:32 PM
Beatriss:
Take a look at the Model View Options associated with the plan Views: Model View Options > Override Fill Display.
David
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-01 09:04 AM
‎2011-06-01
09:04 AM
David, maybe I don't understand something. My fill override is disabled, which would mean that it should display the way I set it, correct?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-01 09:16 AM
‎2011-06-01
09:16 AM
There is a similar -but display only- setting in trace options: Transparent zones and Fills. If it is on, turning it off should help.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2011-06-01 09:40 AM
‎2011-06-01
09:40 AM
restricted wrote:That solved it! Thank you so much!
