Floor Plan Cut Planes
I am trying to change the cut plane of my floor plan. I have used the 'floor plan cut plane' tool, which does successfully adjust the plan. However when I change floor and the return to the original, the cut plane has defaulted back to the original cut plane.
How do i stop this from happening and keep my floor plan with a custom cut plane?
Many thanks,
Emily
4 Replies 4
vistasp
Mentor
Emily, I'm not sure if this thread is useful but have a look. It refers to a possible bug in the AC 10 template:
http://archicad-talk.graphisoft.com/viewtopic.php?p=87350
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Hi vistasp,
Thankyou for your response. That thread was helpful, and I have been able to figure it out:
As I am working in our office template, these settings over-ride the required floor plan cut plane. To get around this, you must right click the storey and select 'view settings'. In this box you can go to the Floor Plan Cut Plane Settings dialog box and insert your required value.
This will ensure the cut plane stays at the required value when switching between storeys.
Thanks,
Emily
owen
Are you navigating via the View Map? FPCP settings are stored with views, so it could just be they are changing back to the settings stored with that view?
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
owen
Aha .. you worked it out as i was replying.
cheers,
Owen Sharp
