EliesH
Generating
My computer keeps generating one facade. I have purged my library and other options.
I can load everything else except my front view. Has anyone encountered this problem before, and how did you solve it ?
3 Replies 3
Gordana Radonic
Community Manager
Community Manager
Hi @EliesH,
Maybe try changing the type of the elevation marker, if the 'Horizontal Range' is infinite, set it to the 'Limited Depth' one. Other suggestions are: turn off all the layers that are not necessary in the elevation view (furniture that is not visible, for example), try setting the update of the drawing to manual (if this automatic starts every time you open a layout), and finally place a new elevation to see if it will have the same generation issue.
Best regards,
Gordana
Gordana Radonić
Community Manager
EliesH
Thank you for your answer. I tried this but it still won't load. Do you have any other suggestions ?
Thank you
Turit
Isn’t there a lot of Solid Element Operations in the plan?
